Transmission guys inside. Is my tranny failing
Today, I started the car and started to go and it shifted in 2nd fine,but before I got to the stop sign I noticed the rpms was up and it would not shift or shift if I let up on the gas. The faster I went the higher the rpm and it still would not shift. At the stop sign, the car was still revving up at a higher rpm. I put in neutral and it still was like i was giving it gas. NOW, when I put it back in drive. BAMMMMMMM! Slammed into gear ******* hard.So hard it sounded like the tranny tail hit the bottom of the floorboard. ****! So I stomped the brake and turned the car off and restarted. Car ran fine. There are no ses lights or codes. WTF, I am thinking I am a shift or two away from total failure. If I haul ***, from a stop it will not even hit 3rd gear. Today, I was going 80 at 4500 rpm and no shift to 3rd until I let up. Thinking I need a performabuilt level 2!
