4l80 Trans brakes/mvb ??
Well got my new trans in and need a MVB trans brake for it. i drive this car on the street so full engine braking will be needed.. I know CK's fmvb will allow this. how bout the new TCI rmvb ? any info tips and horror stories as i dont mind spending the 750 bucks but only wanna do it once..
Thanks in advance
Thanks in advance
im in the same boat. im looking for a rmvb but ive been looking for some reviews on the tci and i cant find any. IMO i think pulling the shifter to upshift is going to be easier and faster than pushing forward. but thats personal preference.
The RMVB was originally designed because of the circuits used for a transbrake on a TH400. For some reason they have become popular due to the "neat" factor I guess.
I've talked to some other big name builders who have used the TCI, they buy my setup now for what that's worth.
Although they did say it worked, which is more than I can say for some I've tested.
ive got a question. correct me if im wrong. but i plan on putting a ratchet shifter in my car with the new tranny. so if i go with a fmvb that means ill have to shift from park all the way into 1st before i take off. then when i am done driving ill have to go from first all the way up to park. so will i be sitting in the car shifting about 6 times to get the car from 1st into park? and if i had a rmvb 1st would be right below neutral so it would be way easier to get into park or reverse. ive never used a ratchet shifter so im still trying to learn how they all work.
Thats the main reason is i have a shifter already.. my car is so light with my th400 and 2.73 gears i could drive around in 3rd with no probs..
Jake so its $650 for your complete setup? fmvb with pro tree brake!
Could please someone in short explain what is transbrake (besides it locks fwd and reverse together) and what is manual valve body? I'm new to this, but sold my T56 planning to install 4L80E.
Is it $500 for MVB with transbrake?
Also what is the shift pattern with such setup?
Thanks!
Thanks!
Gingervitis Addict
Thanks!
Thanks!
Jake's transbrake is a forward pattern (same pattern as stock).
Gingervitis Addict
However, it is possible to tune the PCM to act just like a full manual, if you wish to do so.
Correct, the transbrake is the expensive part.
Transgo has their own full manual valvebody, but it turns the valvebody into swiss-cheese, so to speak. It does work, however they do not have a transbrake for it.
Transgo has redesigned their full manual kit. I haven't used it since the redesign since we have our own full manual setup now, but I may be able to make the transgo full manual kit a transbrake, I would have to see it.
ThransGo HD2 shift kit that I often see mentioned - what is it? Does it add any new functionality, or just makes shifting "sportier"? Or I don't need it at all if I want manual control and transbrake?
So I either buy manual VB and then PCM can't change gears, or I stay "full-auto" and then I can't manually change gears?
