4l60E questions, Can I make this work?
I got a good deal recently on a 4l60E transmission that has been rebuilt with several 4L65 upgrades. It looks to be a truck transmission with the traditional gen1 sb/bbc bellhousing. It looks like the bell can be un-bolted and taken off and the tail shaft has 6 bolts that holds it on as well.
I would like to use this behind my ls1.
What kind of converter will I need? Would a f-body converter work?
Can I get an aftermarket harness that will run the newer motor and make the trans peform properly as well? ie. lock up etc...
I can take pics of the trans, input shaft etc if that will help.
Thanks
Thanks
