torque convertors
I'm not sure about all converters. But, with mine, I can't hold the brake and try to stall it all the way up to where it flashes. At about 3000 or so, it starts trying to move the car.
a converter will usually not stall as high as advertised. lots of factors determine stall speed. traction, power, weight of car, gearing etc. flash speed is another thing, flash speed is the rpm the car will rev to when you quickly punch the throttle. flash speed is usually a more accurate way of naming a converter and is what will help the car launch harder on the street. [when your not always taking it to max stall speed]
power braking you apply the brake and bring the rpms up slowly,like a burn out with out a line lock.good for destroying U-joints.flashing you just mash the gas as fast as possible,removing you foot from the brake at the same time.if you drag race with out a trans brake you will under stand.
