4l80e swap questions
I am swapping from a T56 to a 4l80e. i have a couple questions.
First what flexplate do you recommend? I don't have a converter yet.
next what shifter do you recommend? I will be running a manual valve body so I don't want a ratchet shifter but want something to put in the factory 6 speed counsel.
Thanks, Chris
Thanks, Chris
I went with the TCI flexplate as well. If I remember correctly it had the bolt holes for a 60 and 80 converter. My converter did as well from Yank, so I had 6 mounting points as opposed to 3. Overkill I'm sure but nice to have. Don't forget new bolts. I used ARP.
I'm putting a 6.0 LQ9 in a 91' RS Camaro, I just picked up a 4l80E for it, Hawks third gen makes an LSX swap crossmember for the 4L60E, will it work for a 4L80E or is it a different size/length, also, will I need a custom drive shaft. Hawks was not sure because he said "it should work" I want to know if it "WILL" work!!!
Scroll down for the dimensions. There's 6+ inches in difference in the length to the motor mount alone.
http://www.tciauto.com/Products/TechInfo/trans_dims.asp
