Stall in now no reverse
I had a perfect tranny , I put my stall in put it back together . Now here is the problem i have foward gears and park but no reverse ? Cant figure out what could have happen taking the tranny out and putting it back in to make it stop working ? ( 4l60e)
did you do any internal mods Boost valve maybe. If the boost valve doesnt get seated in right it can casue that. there is a groove above the actuall snap ring groove that fakes alot of peopl out its basically a casting flash and it will hold the snap ring kinda like the real groove will cause a no reverse issue and sometimes you will have forward gears also. Just askin?
Yes here is the update ( ZZ99ls1) had me in the rght direction , i picked the car up and the linkage was not connected to the braket , so when i switched the lever the cable was moving freely . I cant believe i missed it ! Thanks for the help
