Which flexplate? Vig LS1 converter to LQ4
Old 01-16-2011, 10:22 PM
Earl Filter's Avatar
Default Which flexplate? Vig LS1 converter to LQ4
I have a used Vigilante LS1 to 4L80E converter. I'm using it with an '04 LQ4 6.0 that had a 4L80E in it. I have to switch flexplates since the original LQ4 flexplate has 6 holes on the wide pattern for the stock 4L80E. I would guess I could use a stock LS1 F-body flexplate with the 4L60E pattern. Would the flexplate from a 5.3 truck that had a 4L60/65 be the same as an LS1 flexplate? This seemingly simple thing has gotten me confused, especially when I read up on the aftermarket flexplates.
Old 01-18-2011, 01:29 PM
I got a stock GM f-body flexplate to use. Can anyone tell me a reason it won't work? I figure I have the same crank in my 6.0 as the 5.3/5.7 engines, so I should be able to put this on (no spacer) and go. Correct?
