LT-1 4L60E behind an LSX
Old 01-18-2011, 08:09 AM
5LTRETR97's Avatar
Exclamation LT-1 4L60E behind an LSX
I recently did an LSX swap in my 97 Camaro. To save some money I kept the LT-1 4L60E and rebuilt it. Had no problem getting it in, but now the bottom piece of the transfer case will not fit. I know the LSX 4L60's had one piece, but I didn't know if anyone knows of how to get this piece to fit. Any input will help guys. Thanks.
Old 01-18-2011, 11:00 AM
thunderstruck507's Avatar
4 wheel drive camaro?
Kidding aside, you do any research about using that transmission or just slap it on there? The input shaft is different for sure.
Old 01-18-2011, 11:11 AM
Restricted User
z99ls1's Avatar
Transfer case lol. I think you just mean the belhousing
Old 01-18-2011, 02:14 PM
fc_soldier's Avatar
Sweet 4 wheel drive.
I dont think you should have any problems mounting this. I did it with my 1996 corvette. Im running a early 4l60e with a LS2 flexplate and spacer. It bolted up fine at the bell housing. I dont see where your problem is unless you have issues at the tailshaft. Meaning you mounted the tailshaft on your crossmember and now it wont reach at the bell housing. If thats the case you need to do research to make it reach for the distance.
Old 01-18-2011, 03:18 PM
5LTRETR97's Avatar
Yeah, my bad. Bellhousing is correct sir.
Old 01-18-2011, 03:20 PM
5LTRETR97's Avatar
Tail shaft is good. It's that aluminum piece that covers the torque converter and hooks to the bellhousing. It will not slide behind the flexplate. The spacer you are reffering to, is it that piece that goes in the crank that the torque converter slides in? I have that piece in as well. Thanks for the input guys.
Old 01-18-2011, 03:22 PM
5LTRETR97's Avatar
As far as TCI had told me, it should work fine. Except now this piece will not slide in and bolt to the housing.
Old 01-18-2011, 03:26 PM
5LTRETR97's Avatar
I will try and take some pics tonight to show what my issue is. Thanks for all the input.
Old 01-18-2011, 04:35 PM
Restricted User
z99ls1's Avatar
You have a 4l60 converter lt style or 4l60e converter on it ls style?
Old 01-19-2011, 08:02 AM
5LTRETR97's Avatar
Using a LT-1 style converter. Have an adapter for the crank for it to fit.
Old 01-19-2011, 09:51 AM
Circle-D's Avatar
If you need any help getting this sorted out, give me a call. I can throw a little advice your way.
Chris
Old 01-19-2011, 10:49 AM
5LTRETR97's Avatar
Chris
Awesome! Thanks Chris. I should have pics uploaded later today. I will give you a call this afternoon though. Thanks again.
Old 01-19-2011, 10:58 AM
5LTRETR97's Avatar
Here are some pics.
Attached Thumbnails LT-1 4L60E behind an LSX-hpim5006.jpg   LT-1 4L60E behind an LSX-hpim5007.jpg   LT-1 4L60E behind an LSX-hpim5008.jpg   LT-1 4L60E behind an LSX-hpim5009.jpg
Old 01-19-2011, 11:00 AM
5LTRETR97's Avatar
Trying to get the piece thats in the first pic to go around the converter. The other two are just pics of the tailshaft. "fc soldier" was asking about the tailshaft. Thanks.
