blowing thru converter question
Old 01-23-2011, 04:54 PM
mike13's Avatar
Default blowing thru converter question
Here's my dyno, it's a 4000 vigilante converter spec'd for 500 horsepower, I now make a couple hundred more, is this look like the converter is slipping? In the datalog there is over a 800rpm discrepency between rpm and mph. The green line is the boost and you can see as the boost takes off the graph gets all crazy. No wheel spin.
Old 01-24-2011, 10:00 PM
mike13's Avatar
anything from the converter manufacturers?
Old 01-26-2011, 08:17 PM
mike13's Avatar
Anyone else see this before?
Old 01-27-2011, 07:03 AM
ThreeHonks's Avatar
hmmm that is odd looking. Is it a 60e? was the converter locked during the pull?
Old 01-27-2011, 08:31 AM
mike13's Avatar
Yes 4L60e , no the converter wasn't locked, the converter felt pretty loose on the street and I think the dyno just compounds that. I think the converter flashes to where you see the boost shoot up, as the load on the motor is what would build boost.
It says I made 445rwhp with a 383 (ls1 based) with Patriot heads, 224/228 cam, 80mm turbo at almost 17lbs boost.
