Vigilante Converter
We sell atleast 100 Precision converters a year and have had great luck with them.
402GOAT that damage looks like what we have seen from impropper converter spacing. No matter whos converter you install you HAVE to check for propper pump engaugement. Sometimes the converters require shims between the converter and the flexplate. It is completely normal, but if the spacing isn't checked failures like you had are the result.
11 Second Truck Club
I have had 3 different Precision converters in 3 different vehicles over the years. The quality has been as good as anyone elses (any mechanical item can be faulty or can be broken) but get ready to get "Jack-ed" if you have a problem. Anyone who has ever had a warranty issue with them and dealt with Jack will know what I am trying to say.....
Restricted User
This is what happens when you don't check your spacing and you pull the converter to far from the pump. Looks like you didn't install it right to me... Did you check your spacing or just throw it in there and bolt it in?
