About to order a Yankss 4000, dr's,ect..
I'm going to order a Yank ss 4000 stall, mt et streets, tranny cooler, and new flex plate! Anything else I should get for the new stall? I know I'll need tranny fluid. lol
OP, consider a tranny temp gauge. You can pull the pan, replace the fluid and filter and run the pan up to the muffler shop and have them weld your bung in your stock pan while its off. Nothing more valuable then actually knowing what your trans temp is at all times.
They come with the converter.
The gauge is helpful for a lot of reasons. If you are overworking yours trans you can see it. You can see how the ambient temps change the trans temp and can tell if your cooler is working correctly or adequately. You can monitor cool downs at the track before you choose to run again, or hot lap and know that your are not overheating the trans. Its just such a handy device.
