Pros and cons of running stock and aftermarket cooler?
#44
Roger that. I guess i will find out soon when i do the gauge install. Here's a question, which way is a more accurate reading for the gauge, going into the pan or the pressure port?
#46
I have a b&m 70266 cooler in front of my radiator with the AC condenser removed. I'm using braided steel lines from transmission to cooler. I have a digital temp gauge with the sending unit in the pan.
Today is 80 degrees here in Minnesota and I just got done pounding on my car a bit and the highest my temps got were 160 degrees when I came to a stop at a light.
I also have a yank ss3600 and lockup is set to lockup in 4th above 40mph only
#47
Moderator
The internal temp sensor is quite accurate; various multi-function gauges can display it through the OBD port.
