lt1 4l60e and the LS1 swap
Old 01-28-2011, 11:04 PM
96TransAmboosted's Avatar
Default lt1 4l60e and the LS1 swap
I wanted to know if my 1995 4l60e will bolt onto a ls1? what would be the fix if not? I want to swap an ls into my car and have a nice tranny already. thanks
Old 01-29-2011, 10:27 AM
Jays_SSZ28's Avatar
Bolt it on just like a th350, th400, 700, etc. Converter pilot spacer and flexplate mods.
Or custom built old style converter with LS1 type crank pilot and mounting pads.
Read the stickey threads or search, this is asked a lot.
Old 01-30-2011, 08:14 AM
Well Jay, I looked all over the place before i posted the thread. I even looked at comparisons of the 2 transmisiions. I know the early 4L60E will bolt on i did not know i would need a new flex plate and this spacer you mentioned. Im taking it that means the early 4L60e the converter sits back a little further than the ones that come with the LS1. or the converter used is diffrent? So the LS1 PCM,and harness will plug into and control the early 4l60e? If you know where the thread is and can guide me there it would be much help.Thanks
Old 01-30-2011, 09:33 AM
Jays_SSZ28's Avatar
This was on page two https://ls1tech.com/forums/automatic...0r4-4l60e.html .
You didn't ask about plugging the LS electrical into the 1995 transmission so I didn't comment, but thats not going to work.
Old 01-30-2011, 10:36 AM
Thanks i need the info, but still dont see the PCM plug question i had.
Old 01-30-2011, 11:23 AM
Jays_SSZ28's Avatar
I said above, it won't work. Maybe with some heavy modifications it might, never tried it so I don't know.
Quick Reply: lt1 4l60e and the LS1 swap
