4l60e getting stuck, not shifting propertely
Old 01-30-2011, 11:37 PM
needtransam's Avatar
Default 4l60e getting stuck, not shifting propertely
Well my issue is that my auto transmission is getting stuck in gear when i get around 50mph it gets stuck i believe 3rd and doesnt shift up propertely and have to give it a lot of gas for it to shift? Car is a z28 with 100k miles
Old 01-31-2011, 09:16 PM
LS1Tech Sponsor
performabuilt's Avatar
You need to have car scanned for codes first you may have and electrical issue or sensor out of range
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 02-01-2011, 09:32 AM
It doesnt have codes as far as i know would a tranny shop check it?
Old 02-01-2011, 03:38 PM
so do you think it can be internal from the tranny or something that can be fixex?
Old 02-01-2011, 04:35 PM
LS1Tech Sponsor
Well and internal issue is always possible however shift issues as far as timing and kickdown are generaly not trans but electrical issues. You need to find out if and or when the command to shift is being given via a scanner or tuner.
__________________
Call 888-744-6542
Old 02-02-2011, 01:50 PM
Oh i see then i need hp tuners
Old 02-02-2011, 06:00 PM
racerrit's Avatar
No actually any good scanner gives data and u can watch it shift and c if solenoids are working properly. you most likely have a bad sol. or a sticking valve in valvebody
Old 02-05-2011, 11:21 AM
so I should check that first right?
