6l80 awd
6l80 awd
i am currenty installing a ls2 in my 1993 typhoon my goal is to keep all wheel drive i purchased my motor combo trans 6l80 from speartech so all wiring is done to run correctly what i need help with is the transfer case they say i need a 2007 or newer case from a awd escalade to adapt to the 6l80 they use 2 types of cases a single speed and two speed could i put the single speed in without the use of stabilty control or any wire hookup at all any help please i tried the hi tech section but nobody will repy
I would try the guys over at www.performancetruck.net or www.pirate4x4.com They know their transfer cases! Worst case you could always use a Trailblazer SS's!
