lookin for cheap 80e swap parts
just picked up a fresh 4l80e and ive been lookin in all the sponsors sites for swap parts.. found a crossmember with torque arm mount for 240. yank had one a little cheaper.. i still cant find a manual valve body for it,
can i run the 6 bolt converter and just get a 6.0l flexplate?
and where is everyone getting the yoke needed to run the 80e? the guy i bought the transmission from gave me a yoke that looks like my rear end yoke. it has the 2 straps.. so could i just use that and just have a u joint on the driveshaft?
Yes to the 6 lug converter/6L flexplate.
And no to the bolt on yoke, that's for a vehicle with a 2pc driveshaft that has the slip yoke in the shaft. You'll need the standard 32 spline tranny slip yoke, like a 4x4 truck has, depending on which u-joint size you'd prefer to have (stock driveshaft or aftermarket?)
