What ARP Bolts for TCI Flexplate to Crank
Hi all, I've been searching and can't find a definitive answer on which bolts I should get for the SFI TCI flexplate to crankshaft. Block is a forged bottom end ls1 with stock crankshaft and built 4l60e from flt. I'm getting this plate from Chris from Circle-D with my new converter.
I've found the following:
ARP 330-2802
http://www.ws6project.com/user_stor/...oducts_id=1373
Will those work?
ARP 330-2802
Will those work?
so did you end up using the 244-2901?
I'm looking for a set of bolts for my flex plate right now...
from what I can tell, the 330-2802 kit is for flywheels, not flexplates? Didn't even realized they both used separate hardware to the crank until I started looking at these part numbers.
