shifter choices
Old 02-14-2011, 10:55 PM
+badss+'s Avatar
Default shifter choices
im going to be converting my 4l60e to a jake shoe 4l80e soon into my 2002 camaro ss what shifters work using a a4 console...thanks
Old 02-16-2011, 02:43 PM
+badss+'s Avatar
anyone? or what has to be done to use stock shifter...
Old 02-16-2011, 03:24 PM
Gingervitis Addict
slow67's Avatar
I've been told the stock shifter works, but I had a T56, so I bought a ratchet shifter. The 4L80E uses slightly different brackets for the pan/lever. I used a quicksilver.B&M now makes the pan/lever kit for 4L80Es.
Old 02-16-2011, 05:22 PM
ShevrolayZ28's Avatar
Got a link to the pan/lever kit? I had to modify some stuff to get mine to work and it was a PITA to adjust (working alone).
Old 02-16-2011, 06:48 PM
+badss+'s Avatar
thanks slow soon ill be joining the jake shoe club lvl 2 with a tbrake ordering in about a week or so when taxes come in so im trying to get all the info needed to do swap asap
jake seems like a really smart guy when it comes to the 4l80e
Old 02-16-2011, 07:23 PM
Bro, you'll probably gain a full second in ET with a good stall and an A4
Old 02-16-2011, 07:36 PM
badblazeSS's Avatar
x2....
Old 02-16-2011, 08:15 PM
+badss+'s Avatar
yeah i wont have enough for a billet converter just yet so im getting a single for now jsut to get swap done not sure what size to go with tho but ill go over it more with jake when im ordering it car is stock power with only little things done so far but should be fun trans brake and sticky tire = all
Old 02-17-2011, 06:52 AM
Doing the drive train first is a good way to go. You'll have a trani and rear that should do fine on the brake and with a tire. Don't forget the drive shaft and a good trani cooler! And don't forget to ask Jake what he thinks about using the brake with that converter. Don't want any breakage along the way.
Old 02-18-2011, 09:58 AM
+badss+'s Avatar
car has a cooler already and the rear comes with a strange 3 in. chromoly drive shaft set up for the s60 to 4l80e with upgraded u joints and yokes.. id be happy with a full second with mostly stock power might tickle it a lil maybe a 75 shot for now she how it goes..
Old 02-21-2011, 01:40 PM
1badzee's Avatar
B&M Pro Ratchet shifter here for my TH350. I love the shifter. Very simple to use and looks decent. I gutted/cut the stock shifter cover so it fits nice and snug. Doesn't look terrible IMO:
Old 02-21-2011, 10:25 PM
+badss+'s Avatar
looks good, i have a ratchet but it doesn't have the rev lockout handle or neutral safety switch. i might just buy a new one, but i have the t-handle with button already so ill use that.. i guess
