700r tailshaft in 4l60
Old 02-23-2011, 09:47 AM
bigal's1991's Avatar
Default 700r tailshaft in 4l60
ok, im swaping a 5.3 into my 91 camaro i have the ls1 intake, ls1 manifolds, kwik ps and alt bracket, im new to ls1 tech. im having trouble finding a 4l60e for a camaro/firebird for my swap. can u swap the tail shaft out of a 4l60e and a 700r4? i need the tourque arm mount..... thanks. i found a adaptor to put the 700r4 tailshaft on a 4l60e, would this work? would the vss still work? thanks
Old 02-25-2011, 09:22 PM
straightleg's Avatar
don't bother swapping, change the trans crossmember to an aftermarket that relocates the torque arm to it, its alot better setup. my is from spohn performance. I have the adjustable torque arm and mount, works great.
