th400 cooler lines? what size
Old 03-01-2011, 12:47 PM
Busy Mopper's Avatar
Default th400 cooler lines? what size
-6 is what most of the coolers have on them so id assume that this size will work. is anyone running any larger size?
Old 03-01-2011, 09:54 PM
Moderator
Vince B's Avatar
-6 is just fine for what you are doing. Vince
Old 03-02-2011, 06:29 AM
forcd ind's Avatar
i have always used just #6 with the stainless teflon lines, not the standard stainless rubber ones-orig lines were only 5/16" anyway
ATI has #8 fittings, a few guys used them on super loose converters, with massive coolers, and external filters
Old 03-02-2011, 09:09 PM
LS1Tech Sponsor
FTICONVERTERS's Avatar
Dittto with Force, We run #6 on regular set ups and #8 on boosted cars or big power units. the case must be drilled though or you are simply going to put a 1/4 to #8 fitting and gain nuthing. If the case is stock run #6
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 03-05-2011, 09:14 AM
FasTimeSS's Avatar
It will be on a boosted car
Quick Reply: th400 cooler lines? what size
