Pretty sure my converter isn't locking up...how to make sure that is the problem?
Old 03-02-2011, 09:29 PM
aaron653's Avatar
Default Pretty sure my converter isn't locking up...how to make sure that is the problem?
It seems like my converter isn't locking up...My car is at higher rpms in 4th than it used to be and there is no "lockup" feeling when I hit the right mph. How can I make sure it is the converter before I pull the tranny out
Old 03-02-2011, 11:30 PM
remauto1187's Avatar
Drive the vehicle up to 50 or above and coast at that speed and then tap the brake and you should feel a slight jerk which is the lockup disengaging.
Old 03-03-2011, 09:49 AM
thunderstruck507's Avatar
Howdy stranger.
Hit me up sometime this week and I'll help you take a look at it.
Old 03-03-2011, 10:19 AM
pimpjames's Avatar
My car has a 3600 stall and I actually have a problem where the car shudders at 50mph. over and under 50-60 and its fine. you think its a lockup problem as well?
Old 03-03-2011, 10:37 AM
Moderator
jimmyblue's Avatar
You should get it scanned while driving, look at TCC_Mode
for "intention" and TCC Slip RPM for "result". Look for tranny
slip codes that would prevent it from trying. If it says "locked"
and isn't, then look to your line pressure and TCC duty. But
that converter series (TCI Streetfighter) has some of the most
wimp clutches around. Once they slip, they loves to slip.
Old 03-07-2011, 06:47 PM
Here is a log of the TCC setting along with slip, and input/output speeds
File Type: efi
Old 03-07-2011, 09:41 PM
aaron653's Avatar
Thanks
Old 03-08-2011, 11:02 AM
joecar's Avatar
Also, there are several TSTATE pids which show reasons why the PCM is unlocking the TCC.
Old 03-08-2011, 01:01 PM
aaron653's Avatar
Not sure what this means
Quick Reply: Pretty sure my converter isn't locking up...how to make sure that is the problem?
