putting a ss3600 converter in before cam hurt??
i need to replace my rear main and while the trans was out i was going to put in a shift kit, and a YANK ss3600 converter in.
nitrous, long tubes, 3.73 gears, weiand intake, spraying 150.
it will be like this for a little while before i do heads, and cam, or will this kill the car..?
Yes it will destroy your car don't do it; just sale me your stall No but seriously you should be fine and actually notice a gain over the stock stall, I say go for it and I am sure others will say the same.
Restricted User
It will change the way you feel about the car for sure. That's right were I start lsx converters. Throttle response, wot runs, overall seat of the pants feel is great. 3600 is great for stockers to bolt on's.
awesome input, im doing the trans cooler before i even remove the trans. should i do anything else to the trans while its out, a mild rebuild??? theres some miles on it but runs strong still.
it has 130,000 miles, i wasnt doing a shift kit..cause of the miles
cant afford to replace the trans, will a converter kill it?
if it does i can still reuse the converter later right? it wont destroy it
My first real mods were LT's and a Vigilante 3600 in my old Camaro. Wow... it woke that car up! Best first mods by far.
I just read the last post and laughed. My transmission went out a few months after having the converter. The car had 110k on it at the time. I bought a RPM 4L65e and it was worth the $$. EVERY person I know that has had a 4L60e transmission in a Silverado or Lsx vehicle as replaced it at least once... I even had a good trans cooler too...
if you have a good friend who works on trannys install some new clutch pacs and inspect the inners.and consider a deeper pan.if your trans fails have the converter and lines flush out,and change the filters a couple of times with in the 1 100 miles.
where would i get a clutch rebuild kit?
well im guessing with my miles, its pointless to even put a converter in it, without doing a rebuild
The Yank SS3600 is a great choice. You'll see some nice gains all around. I would recommend freshening up the tranny (as mentioned above) along with the Trans Go shift kit. Tranny cooler is a must. The convertor and shift kit alone will amaze you!!!
