vortech 4l60e input shaft swap. HELP!!!
Old 03-09-2011, 11:00 PM
crankstart's Avatar
Default vortech 4l60e input shaft swap. HELP!!!
I have a 1998 4l60e from a k1500 chevy truck(vortech 350) and i built an iron 6.0 i want to mate to it and i see the pre ls 4l60e has a different input shaft and i was wondering if i can buy the newer 300mm shaft and swap it. and if so do i need any other parts?
Old 03-09-2011, 11:46 PM
98 4X4 burban's Avatar
yes you can swap the shafts out. i am not sure on the bell houshing but i think the ls is about an inch deeper than the non ls bell. i hope someone can confirm that.
Old 03-10-2011, 12:23 AM
Bo185's Avatar
Why not just get a dished 5.3L flexplate and spacer for the crank and elongate the holes of the flexplate to fit the Earlier 4l60 torque convert bolts. Or you could use the stock 6.0L flat flex plate and so the same won't need the spacer.
Old 03-10-2011, 05:56 AM
Moderator
Vince B's Avatar
If you plan on swapping the input shafts you will need to change the pump stator and also the bell. Vince
Old 03-10-2011, 06:03 AM
crankstart's Avatar
? swap the bell as in the whole case? because the bell housing is one in the same as the case. Now i'm really stumped.
Old 03-10-2011, 06:11 AM
Moderator
Vince B's Avatar
My bad I was not thinking. The cases in your truck did not change until 99! What I would do in your case is leave what you have in the trans alone. Install the unit as if you were installing a th350 or th400. This will require a custom converter or a crank pilot spacer. HTH Vince
Old 03-10-2011, 07:37 AM
Circle-D's Avatar
I agree with Vince. You can use the LT style 298mm converter. You can mod the flex-plate bolt holes for the smaller bolt pattern. Also need to make sure the pilot of the converter is engaging in the crank. You will need an adapter if you are using the dished flex-plate. If you are using the flat style with the spacer, you should be fine.
Chris
Quick Reply: vortech 4l60e input shaft swap. HELP!!!
