4l60e help!!!!
4l60e help!!!!
So after my car sitting for about 3 days. I jumped in to take a drive and about 4 blocks down the road the tranny just lost all gears. Now when I turn it off,and start it again it'll run and drive for like 2 block then no gears again! I've had no problems til now the trans is a proforma built stage2,and fuddle 3500 stall someone said the front pump is out any ideas
hmmmmm does this ussualy happends to does performabuilt Trans? i was about to order one, but decideit to read here first not happy...
Ok well I change fluid,filter,and solenoids but now here is the problem. The car drives but feels like only 1,2 and overdrive is working and if I manual shift it the trans make a thump like its dropping in to that gear.
Any thoughts about this?
