93 Camaro shifter question.
Old 03-21-2011, 01:22 PM
jdway93z28's Avatar
Default 93 Camaro shifter question.
Did some Camaro shifters not have first gear
Old 03-21-2011, 01:54 PM
Snapps's Avatar
Yes they did, it was an option with the 2:73 rear end gears, also had all season radial tires. My 1997 Trans am had the same thing, so I just popped off the cover of the shifter an dremeled out the little plastic piece that keeps ya from going into first gear. Hope this helps ya..
Old 03-21-2011, 03:33 PM
jdway93z28's Avatar
Can you show me a pic of that peice?
Old 03-21-2011, 03:37 PM
Snapps's Avatar
I don't have the car anymore but once you remove the shifter cover you will see the little black plastic piece I am talking about. If you don't have a dremel just take sometgung an bend it back out of the way.
Old 03-21-2011, 03:56 PM
jdway93z28's Avatar
Ok. I found it right after I posted. Just cut it with a razor knife.
Old 03-21-2011, 03:57 PM
jdway93z28's Avatar
Thanks!!!
