Leaks cooler line into trans case!
Old 03-29-2011, 04:30 AM
damn's Avatar
Default Leaks cooler line into trans case!
Aaahhhhhhhh spent all day trying to fix this leak! Its only leaking a couple drops every 10 minutes but i have a new trans and dont want any leaks. The 1/2in nut is basically rounded off somehow and i cannot seem to find an oem replacement.
Does anyone have any idea's? Today i lowered the trans as much as possible but still couldnt get it to tighten down so if anyone knows where to get new lines could you point me in the right direction.
I looked into the braided lines setup but i cannot find a definitive answer to what i actually need to get to do it.
Old 04-01-2011, 06:41 PM
Chubbz155's Avatar
i know that if you tighten that fitting to much it will crack the case. I tightened the top fitting (return line) on my trans and it cracked the top of my case. Also if it is just the fitting try going to a trans shop and seeing if they have one laying around.
Old 04-04-2011, 09:58 AM
Jeremy@RPMTransmissions's Avatar
Give me a call if you want to get new fittings. You will need to put some thread sealent on the fittings to keep them from leaking too.
Old 04-04-2011, 12:11 PM
01ssreda4's Avatar
https://ls1tech.com/forums/automatic...oler-line.html
