Trans crossmember for 4L80e swap
Old 04-01-2011, 07:38 AM
evo462's Avatar
Default Trans crossmember for 4L80e swap
I need to get a crossmember for my 4L80e swap. I am keeping the stock rear and and torque arm for now, so I need a unit that'll take the stock torque arm.
I have been looking at the BMR piece:
http://shop.brutespeed.com/BMR-TCC02...BMR-TCC021.htm
but it says it is meant to work with a BRM torque arm, but may work with others by swapping the bushing out.
Before I order - is anyone running this crossmember with a stock bushing/torque arm?
Thanks!
Old 04-01-2011, 07:53 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
You can definitely run our BMR torque arm relocation transmission crossmember with the factory torque arm, the only thing you are going to need to make it work is the Prothane or Energy replacement torque arm bushing. Other than that it will all bolt right up. If you would like to order one give me a call here at the shop and we can get you taken care of.
Thanks,
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 01-16-2012, 11:02 PM
BLWN1's Avatar
Any luck with your swap?
Old 01-17-2012, 04:09 PM
LongIsland63SS409's Avatar
Thanks,
Kyle
Kyle,
Is the relocation crossmember the same as the swap crossmember except it has the relocation bracket welded to it?
Reason I am asking is that I can get the V8 conversion moving under it's own power using the stock TA and rear. I can then switch to the Ford 9 later.
Thanks,
Mike
Old 01-17-2012, 04:32 PM
BMR Sales2's Avatar
Originally Posted by LongIsland63SS409
Kyle,
Thanks,
Mike
Our relocation crossmember is the same as the conversion crossmember just with a mounting plate added to allow the torque arm to be bolted to it. You can absolutely use our BMR relocation crossmember with the factory torque arm, the only thing you would need to pick up is a Prothane or Energy Suspension torque arm bushing mount to get everything bolted up.
Kyle
__________________
Glenn ***
Sales Tech
813.986.9302
Old 01-17-2012, 04:41 PM
Kyle
Thank you!
That will help me out alot.
Will order one when ready.
Mike
Old 01-17-2012, 04:42 PM
BMR Sales2's Avatar
Thank you!
Mike
Give me a call when you are ready for one.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 01-17-2012, 06:47 PM
BLWN1's Avatar
Pm me a price and do you have the mount? I'm doing the same thing he is stock rear for now.
Old 01-18-2012, 11:34 PM
soundengineer's Avatar
Dave over at Yank converters also makes trans crossmembers, and they are usually in stock ready to ship for the 4l80 in an fbody
Old 01-18-2012, 11:36 PM
BLWN1's Avatar
maybe dave can pm me a price, his use a stock torque arm>
Old 01-18-2012, 11:40 PM
why pm... he's a supporting vendor...has a webpage...has prices listed on the page..
http://www.converter.cc/product_p/yc%20106.htm
Quick Reply: Trans crossmember for 4L80e swap
