Location for Trans temp Sender?
I would like to install the sender for my auto meter gauge into the actual cooler line leaving the trans, like some sort of actual adapter fitting for 1/4npt that is actually about a inch deep to screw the sendering into? any help
worst case i can tap it into the pan.
I used one on-line on my Jeep. Brass t fitting with compression fittings. I just took the sending unit, electronic, in to napa and got what I needed. Mine seems to always have a small drip though no matter what. I went with one in the pan for my Firebird though. Much better in my opinion.
Reading temps going through the cooler lines is a waste IMO. The pan gives you the best average temp of the fluid. And you cant tap the stock pan. You'd have to have an after-market aluminum one for that.
