Gonna swap out the converter. need advice
Old 04-06-2011, 11:06 AM
wicked-98's Avatar
Default Gonna swap out the converter. need advice
I have longtubes on my 98 Z . Do I absolutely have to remove the headers? The reason I'm asking is becaused my headers are welded on to the Y pipe and its a custom setup. I really dont wanna cut them for the TC swap what do you guys think.I'm capable of a tranny swap but always unbolted the exhaust before hand .
Old 04-06-2011, 11:07 AM
Vader TA's Avatar
on my old car i left he stock headers and y pipe on fwiw
Old 04-06-2011, 11:21 AM
wicked-98's Avatar
Did you unbolt anything at all from the exhaust? I'm thinking of loosening the header bolts from the heads
Old 04-06-2011, 09:05 PM
SS SLP2's Avatar
no need to loose the headers or y pipe ( running pacesetters LT and y pipe)
disconnect the y pipe from the I pipe and pull the trans
Johnny
Old 04-11-2011, 01:39 PM
wicked-98's Avatar
Johnny
Its ALL welded from front to back. The only thing not welded are the headers to the heads lol. I crawled under today and it looks as if they will clear by a few mm . The headers seem to spread out after they bend under the floor pan . let me see if I can take some pics
Old 04-11-2011, 02:12 PM
Rushin's Avatar
If it's all welded then 99% chance you're out of luck, my man.
Old 04-11-2011, 02:33 PM
BlueMagicSS's Avatar
I've done a clutch swap in my 00 SS without removing the headers and y-pipe, mine are all welded as well... so you may be able to do it with the auto
Old 04-11-2011, 02:35 PM
shorty(98TA)'s Avatar
i would cut it just so i could weld in the peices to bolt it back together and check all the welds while its off the car. chances are if they fully welded it while it was on the car there are leaks i cant see how there is enough clearence to get a proper weld all the way around the pipe with it on the car
Old 04-11-2011, 04:00 PM
senicalj4579's Avatar
Wen I was going through the process of dropping trans I saw that its without a doubt a pita to try and do it with y pipe there so I took it down. If I didnt have a choice (if welded like yours) I may have found a way to do it. But damn, idk if it would have been possible, I did mine with car off ground maybe 25" and on my back lol.
Sorry but I think its gotta come down.
Old 04-11-2011, 04:21 PM
SS SLP2's Avatar
I suggest cut just behind the y, go the parts house and buy a connecter pipe ( one end large enough to fit over and one end small enough to go into your I pipe) and 2 band clamps you may repair it with out a connecter peice only with a single band clamp
Johnny
Old 04-11-2011, 07:02 PM
wicked-98's Avatar
I was thinking like shorty said but id rather not do extra work if i don't have to unless its making me do extra work lol.
Old 04-11-2011, 08:08 PM
DSkyles's Avatar
I've had my tranny in and out like 5 times now and haven't touched the headers/y/or I pipe. All I did was drop it off the hangers in the back and unbolt the panhard bar to drop the exhaust, which drops the tranny down.
Old 04-12-2011, 02:48 PM
wicked-98's Avatar
nice!!!
Old 04-12-2011, 03:00 PM
wicked-98's Avatar
http://s269.photobucket.com/albums/j...9.jpg&newest=1
http://s269.photobucket.com/albums/j...0.jpg&newest=1
http://s269.photobucket.com/albums/j...1.jpg&newest=1
Old 04-12-2011, 03:16 PM
wicked-98's Avatar
there's some pics I took
