93 tv cable adjustment????
Old 04-12-2011, 12:17 PM
jdway93z28's Avatar
Default 93 tv cable adjustment????
when i try to adjust it it goes to the max every time. is that where it was stock or am i doing it wrong.
Engine off, I push in tab.
Move cable towards firewall
then move cable bracket to WOT.
Old 04-12-2011, 12:54 PM
lt1-xjs's Avatar
That puts you in the ballpark on the tight side. If it doesn't want to shift move it in 1/8" and try it, need more try another 1/8" ect. On early shifts you would move it out. I found that marking the cable was helpful.
Old 04-12-2011, 12:55 PM
jdway93z28's Avatar
ok. i adjusted it a little before max and it started shifting early. so im guessing max is about right. anyone have input.
Old 04-12-2011, 03:38 PM
lt1-xjs's Avatar
Move it out "1 click" at time till it doesn't want to shift, then move it 1 back in, that is max to me. It doesn't get any better.
Old 04-13-2011, 07:57 AM
Dyno paul's Avatar
Default Goes to Max.
Is the cable an Original GM cable or is it a Fits all universal cable.
Quick Reply: 93 tv cable adjustment????
