having an issue with the 2-3 shift @ WOT
Im a noob when it comes to automatic transmissions, so i apologize in advance lol.
Here's the story on it-
in november 2010 i ran it at the track with no issues. at the time i had the stock 2.73 gears and a 3400 converter with a shift kit and my buddy's tune.
added 3.42 gears and 90mm intake/ tb and had my buddy re-tune it for me. part throttle is fine. It will not upshift into 3rd gear at WOT at the track. Also if i go from a slow roll or dig on the street it does the same thing. 1-2 shift is fine and the car pulls hard all the way through 2nd but it wont upshift into 3rd @ wot. It will not shift unless i let off the throttle a little bit to let it shift, then i can get back on it and itll continue to pull hard
Now here is the weird part- When im cruising anywhere from 35-65mph and go WOT, itll downshift into 2nd gear and upshift into 3rd gear perfectly fine with no problems.
I took the car to a transmission shop where a friend of mine works. he hooked up the scanner and found no problems with it. We couldnt do a WOT pull, but he said if the trans had any kind of problem, it'd show up at part throttle
Im pretty sure i attatched the correct HPT file. Any ideas? All help is greatly appreciated
cause i had a similar problem but it was my first gear. and after pulling my hair out i went for a true tune and my shift point for first was not right and that was the problem. might not be the answer but thats the only thing i could think of.
yep, I think there are 2 tables for shiftpoints. upshifts and downshifts. they are good as far as mph/rpm goes. The 2-3 upshift is perfect when im on the highway and go WOT anywhere from 35-65mph. It only seems to have the problem when going from 1st gear. I notice it the most at the track since i can dead hook there. He even commanded the 2-3 shift earlier just to get it to shift, but it would still pull to limiter and not upshift when I'd go from a slow roll/dig
wow. do you know who vince b is. he is a tranny guy on this site. if you can find him, he will know cause the only other thing i can think is a internal problem in the trans.
That the other thing, i had my friend use his transmission shop's scanner to look for any problems that i might have but he didnt find anything. Ill search the members list for him and send a pm. thanks for pointing me in the right direction
I looked at your tune. The shift rpm looks like mine, normal for first and third but lowered for 2>3. Remember mph has to met first, thats why we need a log so we can see and exact reference of mph vs. rpm with the converter flaring. i also think the 100% column on the part throttle table should match your wide open stuff which it doesn't.
Looks like you've got a 6300 rev-limiter. I would bump it to 6500. Honestly, my stock trans would shift at 6450 but not at 6350. **** was weird but thats just what it would do.
