4L60e no second gear
Old 05-03-2011, 11:32 AM
1970's Avatar
Default 4L60e no second gear
2000 Z28 engine and transmission, 4L60e, 2.73 rear gear:
Lot of miles, no transmission servicing lately, fluid looks good.
From a stop, not heavy acceleration: engine accelerates to 4000 RPM before shifting, and drops to 2000 RPM, so I think that it is third gear.
How bad it this?
Old 05-03-2011, 11:49 AM
Jeremy@RPMTransmissions's Avatar
Is there any way you can get it on a scanner and see what gear the ECM is commanding and what gear it is currently in?
Old 05-03-2011, 12:31 PM
1970's Avatar
Scanner said it shifted to second, then to third.
Old 05-03-2011, 01:02 PM
LS1Tech Sponsor
performabuilt's Avatar
Sounds like there is and issue with the 2-4 band possibly tangs broken off which is common with the stock band particulary if you have a shift kit or have upped the presure in tuning, Plus thats alot of miles.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Quick Reply: 4L60e no second gear
