Transmission pump
Old 05-08-2011, 04:31 PM
JOSH13's Avatar
Default Transmission pump
My transmission keeps going through pumps, possibly because of spacing is what my trans guy said. It seems to be spaced correctly when reinstalled .... Anybody have a solution to this problem ? Trans is a 4l60e and yes it has an aftermarket converter, which may or may not be the problem .... It was fine the first 6 months it was in then randomly having this problem repeatedly .... I spaced it last time and it lasted a few weeks .... Any advice ?
Old 05-08-2011, 08:31 PM
Moderator
Vince B's Avatar
Make sure that your doll pins are installed in the block and also that the holes in your bell housing are good. Vince
