having my 4l60e built hows this look?
well years back i had the trans built but it turns out alot of parts that where suppose to be put in werent and the other day the trans took a **** heres a list of what im having done tell me what u guys think
ECS Race 4L6xE Build - Blueprinted 13 Vane Trans Pump with
hardened rings & rotor, Reinforced Input Drum with Input Shaft,
Billet Apply Pistons, ECS Custom 3 / 4 Clutch Pack, New Reverse
Input Drum, Extra Wide Carbon Band, HD 29 Element Input
Sprag, HD Low Roller Clutch, Billet 2nd Gear Servo, Billet 4th
Gear Servo, Billet Pin-Less Accumulator Pistons, 5 Pinion
Planetary Sets, HD Reaction Carrier Hub, New Solenoids, Shot
Peened Output Shaft, Updated Spacer Plate, ECS Prepped Valve
Body with HD 2 / 3 Valve Modification, New
Bearings/Seals/Gasket -- Add Deep Trans Pan & Includes Labor to
R&R -
R&R -
