4L80e/Transgo experts inside please
Old 05-25-2011, 05:10 PM
11 Second Truck Club
L-EATER's Avatar
Default 4L80e/Transgo experts inside please
The Transgo shift kit for the 4L80e includes a bolt for the 4th gear clutch assembly that has a smaller orifice than the stock bolt. Anyone know why they are restricting this particular hole?
Old 05-25-2011, 07:15 PM
Jake's Performance's Avatar
Use a stock bolt.
Old 05-25-2011, 07:45 PM
L-EATER's Avatar
Thanks. I was going to ask you this question today when I called about the sprag and drum but you weren't there so I figured I would ask on here.
Old 10-27-2011, 07:05 PM
Beatdown Z's Avatar
Originally Posted by Jake's Performance
Use a stock bolt.
Could the Transgo bolts potentially cause a problem?
Old 10-27-2011, 09:07 PM
Cam72aro's Avatar
It restricts fluid. I installed the stock bolt per Jakes recommendation.
Old 10-28-2011, 07:57 AM
Gilbert@Ace Racing's Avatar
That's very good advice. I've never used the bolt Trans-Go provides. It's just a bad idea imho.
g
Old 10-28-2011, 03:00 PM
TransGo may have been trying to increase the strength of the bolt, by making it thicker, and as a byproduct making the orifice smaller.
My problem with it is that once I got a core in with a transgo bolt, that was broke off. After attempting to extract it I had to pay $150 to have it EDM'd out.
No reason to restrict it there. You control apply with the orifice in the plate.
Quick Reply: 4L80e/Transgo experts inside please
