Automatic shifter knob removal?
Feel/look around the other side you will see a small horizontal slit/groove, stick a small flat blade screw driver in there to pull out a flat "c" clip that holds the handle on, be careful its a small "Oh Jesus" (I call it that cause if it flies off you'll say...) type clip. To reinstall, just reverse the procedure, less than 60 seconds to do!
