DD Stall
Old 05-26-2011, 03:14 PM
PlowBoy11's Avatar
Default DD Stall
I was thinking about getting a stall for my 98 Z28 not to big just something better than stock. Having to launch under 1500 because it just tries to do a burnout if any higher but this is a daily driver also. And of course I still have the 10 bolt with 4.10 gears so I'm kinda worried about busting the rear axle with the stall and ETs. What stall would yall suggest anyway?
Old 05-26-2011, 04:18 PM
Circle-D's Avatar
A stall will make a huge difference, guaranteed to put a huge smile on your face! We have several options but need a little more info. If you can, fill out an "Ask Chris" from we can get back to you. Link is in sig....
Chris
Old 05-26-2011, 04:19 PM
FirstYrLS1Z's Avatar
10 bolts hold together very well behind a A4.
You stated it's a daily driver, but you didn't state any other intentions, dragstrip, roadracing ?
A stall is nothing more than slippage vs. resistance. For example a 3000 stall with 3.23s' and changing the gears to 2.73s',that 3000 stall would feel like a 3500 stall,changing the gears to 3.73s',that 3000 stall would feel like a 2500 stall.
When I changed my stall from OEM 1800 to TCI 2800(OEM 3.23s'),it felt 'loose' but didn't take long to get used to. When I changed my OEM 3.23s' to 4.56s' that 2800 stall felt/feels as tight as the OEM 1800. Planning on putting in a Yank SS 3600 this weekend.
Since you're running 4.10s' ( good to see 4.10s' in a A4), don't waste your time & money on anything below 3000. A CircleD or Yank in the 3200 range would be a minimum.
the consensus rule of thumb for a convertor,"whatever size you think is best for you,go more"
wanting a 2800 means you'll regret not getting a 3200,or a 3500,or 3600.
go get/take some rides in variously stalled cars.
Old 05-27-2011, 10:06 AM
PlowBoy11's Avatar
I've been to track once and would like to start going a little more often maybe once a month or so maybe get into bracket racing.
Old 05-27-2011, 12:30 PM
zracer323's Avatar
I would go with 3600-400 stall. With the 4.10s it will have pretty good street manners.
Old 05-27-2011, 12:34 PM
skimms98's Avatar
Yank ss3600
Old 05-27-2011, 01:19 PM
PlowBoy11's Avatar
This is a street car that sees about 20-30 miles a day round trip. I would also like to go to the drag strip maybe once a month and do test and tune maybe bracket racing. But this mostly will be streecar for daily comutes and road trips from time to time. Car is all stock would like to do headers and cam this winter.
Old 05-27-2011, 01:46 PM
Quick Sh0t xMLx's Avatar
Get a 4000 stall with those gears. With my 3.15s my 3600 stall drives great around town. It literally took me about 15 minutes to get used to it. Hell my mom has drove it a few times and hasn't complained a bit about it.
Old 05-27-2011, 04:03 PM
hfthe3rd's Avatar
I heart my 4 k stall. Only put 20 miles on it but Damn its fun to drive.
Old 05-27-2011, 04:30 PM
"This is a street car that sees about 20-30 miles a day round trip"
Your freeway mpg is about 22 with the 4.10s', and a 'lockup' stall will have NO effect on that.
My freeway mpg is 21.5 with the 4.56s',and even took 4 trips from Cleveland Ohio to Florida with the 4.56s'.
MPG is RIGHT FOOT DEPENDENT.
Old 05-27-2011, 05:38 PM
garygnu's Avatar
slicks help soften the shock to the rear,the taller the safer.
Old 05-27-2011, 05:51 PM
ULTIMATEORANGESS's Avatar
my triple disc vig 3600 feels like stock.
Old 05-27-2011, 05:54 PM
PlowBoy11's Avatar
Firstyrls1z you are dead on the car gets 22 mpg the car shifts hard into 2nd gear at 2 grand so I ease in too it until it shifts then get on it drops to 17 or so if I get on it from stop and spins bad. I run 26x10.5 DRs at the track then I run 235.60s on the street. Want to go to a taller wider rear tire for street. How wide can you go a stock 16in wheel.
Old 05-27-2011, 05:55 PM
TurbopigB4C's Avatar
My rear end is still fine with stock 10 bolt w/ 4.56 gears. I have a 4400 stall and launch it hard enough to get the front wheels up a bit.
Old 05-27-2011, 06:25 PM
salemetro's Avatar
Holy crap! That's decent MPG....now, I have some idea of what to expect.
Old 05-27-2011, 07:02 PM
8 long trips (1100 miles) with my OEM 3.23s' gave consistent 24.5 freeway/cruise-control mpg,4 more identical trips with 4.56s' gave 21.5 mpg.
Theoretically,based on ratio change,it should have been 18 mpg. The higher numerical gearing gives the engine a better mechanical advantage over the vehicle which in turn means less engine loading. As engine load changes so does the air/fuel ratio. Wide open throttle put the highest load on the engine and the computor richens it up. Freeway cruise-control with 4.56s' has a very low load on the engine and the computor causes a leaner condition,but still within factory parameters.
One of the most useful additions to my 98Z was a ScanGaugeII which shows true RPM,true MPH,intake temp,true water temp,MPG,engine load,throttle position,manifold pressure,to name some.
Old 05-27-2011, 10:03 PM
TXZ28LS1's Avatar
I have a vigilante 3200 and 3.73 and it drives great. Very much drives like stock, and it does hit hard and pull pretty nice. I am very amazed how stockish my car drives with a 3200 stall. I do plan on stepping up to a 4k stall though.
Old 05-27-2011, 10:58 PM
01ssreda4's Avatar
Ss3600
Old 05-28-2011, 12:59 PM
senicalj4579's Avatar
3600 from one of the sponsors. I love my yank ss3600. Oh and im running that on stock 3.23 gear so your gear should feel way better with a stall. Shoot, you have 4.10 gear I would personally go with a pt4000, ss4000 or something close.
Old 05-30-2011, 09:20 AM
PlowBoy11's Avatar
So between 3600 and a 4000 with more lean to the 4000. Thanks guys now I just need to sell my old dodge 12v truck.
Quick Reply: DD Stall
