Th350 Speedometer Cable Block Off?
Old 06-14-2011, 08:39 PM
Lt1Powerz's Avatar
Default Th350 Speedometer Cable Block Off?
Does anyone make anything like this? What did you guys use to block off that hole in the tail shaft?
Old 06-15-2011, 11:14 AM
Moderator
jimmyblue's Avatar
Dunno, but if I were in a ghetto mood I'd get the old
speedo cable, take the collar and collet off, and crimp
/ solder the collet open end.
Old 06-15-2011, 11:55 AM
Jake's Performance's Avatar
Freeze plug.
Old 06-17-2011, 08:17 AM
Lt1Powerz's Avatar
i couldnt find the right size freeze plug so i took the collar, capped the end and jb welded the cap and the collar so its not goin no where
Old 06-17-2011, 09:11 PM
Detroit Gearbox's Avatar
The speedometer gear is designed to supply oil to the output shaft bushing.
They make a block off that holds a gear for just that application.
http://www.sonnax.com/system/announcement/35922-01K.pdf
Old 06-18-2011, 06:22 AM
forcd ind's Avatar
you can just leave the stock housing that the speedometer cable hooked up to with the gear in it, shouldnt leak
Old 06-18-2011, 08:23 AM
Lt1Powerz's Avatar
So far no leaks Hittin the rollers soon!
Quick Reply: Th350 Speedometer Cable Block Off?
