What Stall for 4L60E .... please .
Ls1. 4L60E Auto Transmission
I'm going to start my new project and I want to ask about the Stall Converter because I don’t know so much about stall. My goal is to get one for a (DAILY DRIVE) this is most.
So pls could anyone recommend me a good stall for DD .
other modes :-
CheaTR v.3" - 219/230 .607/.604 117 LSA. Off Idle-6800 RPM Power Band
Stage 2 Ls6 from TSP heads 64cc Chambers comes with Dual Valve Springs650”
102 FAST intake Mainfold
Nick williams 102mm TB.
SLP catback- headrs
SLP Timing Chains
SLP oil pump
OTR air intak
ARB head bolts
push rods 7.400” from trick flow.
040" Cometic heads Gasket
3.73 geare
ACEL 30lbs fule injectors. I have a dubt with these injectors maybe I’ll replaced them with FAST 36.
as I said before my for daily drive ..
Thanks in advance .
other modes :-
SLP catback- headrs
SLP Timing Chains
SLP oil pump
OTR air intak
ARB head bolts
3.73 geare
Thanks in advance .
If you're not spraying I would say a 3800-4000. If you are spraying I would say 3600-3800. Are you going to add gears? They will help a bigger stall ( which would make the most of your setup ) feel tighter....
A lot of people start off with a 3200-3600 and almost always end up going bigger
For sure I’m not going to spray (NOS as I understood ) no no ..
yes i will add a gear ratio 3.73
I know some times I’m asking silly questions but I believe that you have more experience than I do . Hhhhhhhhh
My question is, what does it mean 2800 ,3600 and 4000 stall converter ? what I understood that it means it will come alive ( start perform ) at these RPM … isn’t it .
what do you think is better for high performance and DD and with my modes .
the Breakaway from TCI
http://www.tciauto.com/Products/TC-'...rs'-2.aspx
or
StreetFighter
or
StreetFighter
I would suggest our Pro Series Stage I. Getting something with a billet front is a good investment. If a converter goes out, it will take the trans with it. With 3.73 gears, that cam and being mostly a DD, I think our 2C will be nice. But it really depends on all your goals for the car. I wold love to help you spec a converter out. If you could fill out our "Ask Chris" form and I will get back to you. The link is in sig....thanks...
Chris
Chris
