TC lockup
Old 07-03-2011, 08:04 PM
BOTTLE ROCKET's Avatar
Default TC lockup
Odd question, but how EXACTLY can you tell if the TC is locking up at cruise speed?
I was driving home today, when I noticed my "instant mpg" was lower than usual at 60mph (16-18 instead of the 23-25 normal) The rpm seemed to be a little higher (2000 instead of 1800-1900 from memory) and my trans temps were climbing to the 220 range normally in the 195-200 range although it WAS hot)
I rechecked my lock up values and they seemed correct, but just wondered if there was somthing else to check.
Old 07-03-2011, 08:29 PM
Speedy's Avatar
Check your pump pressure.
Old 07-03-2011, 09:44 PM
How?
Do you mean the settings in HPT, or actual?
It seems to shift normal, and when I go WOT it shifts hard.
What exactly do I need to check and how?
Thanks
Old 07-04-2011, 07:46 PM
Moderator
jimmyblue's Avatar
Are you asking about intention or result?
Just give it a tad more pedal and if the RPMs stay
put while the engine loads up, you're locked.
Old 07-04-2011, 08:28 PM
garygnu's Avatar
if your lock up ain't working try and change your trans fluid a couple of times.
Old 07-05-2011, 03:32 PM
joecar's Avatar
When the TCC locks then it feels like a manual transmission in high gear, and the rpm stays steady, even when the throttle is moved within the range of the apply/release tables without exceeding the curves.
Old 07-07-2011, 10:54 AM
Buzzmanb12's Avatar
The easiest way to check is to drive it. Just get to normal driving speed with steady throttle, at about 55-60 mph touch the brake pedal and watch the tach, if the rpm climbs a few hundred then the converter is unlocking. You should also be able to feel it.
Old 07-07-2011, 12:15 PM
BrianC98Z28's Avatar
If your cruising and give it more throttle and the rpms stay put but you mph is increasing then its locked up. If you give it more throttle and the rpms jump up then its unlocked at that point.
Old 07-07-2011, 07:49 PM
drone's Avatar
play with the shifter.
sounds like you had it in drive maybe.
Old 07-07-2011, 08:33 PM
Thanks for the responses
The three main reasons I was concerned about the lock up was the differeces in;
1. My trans temps, which NEVER go above 215 unless I'm maybe in the mountains (received my new trans cooler today to address that)
2. My "instant mpg" on a flat road is usually around 24-25, but it was in the teens. I was definitly in OD
2. My rpm is usually around 1800 at 60 mph, but was dead on 2000. I verified this by driving my wifes car with has the same rear (3.42) and a stall, and it was running 1800.
The trans is a new (less than 1000 miles) RPM stage V, so the fluid is new.
I changed the pressure settings on the TCC and will download and test again this weekend.
I'll try some of the "test" posted.
Thanks again
