New 4L80E question
Old 07-04-2011, 11:52 AM
Fbodyjunkie06's Avatar
Default New 4L80E question
Just got my 80E rebuilt by Transformance. 6 band clutch packs, straight cut gears, billet hardened input shaft, billet hardened forward hub, basically good to an easy 750-850 rwhp.
It has Jakes "Street" Trans-brake which retains 2-1 shifting while moving and has less violent 1-2 shifting but releases the same as the "Pro" version.
My car is set-up for fmvb. My question is, I usually run only 1/8th mile and will never need to shift into 4th gear at WOT. I have heard and have been told that it isn't good for the tranny to shift into 4th at WOT or run at WOT in OD (i.e. 4th). What's the scoop on this?
I have a billet FTI lock-up converter (single disc) 3800 stall. I was wondering this because I do run on the highway against bikes and I will need 4th gear WOT to do that. Also if I plan on going to a 1/4 mile I am not sure If I can make it through the traps in 3rd gear on a 275/50/15 and 3.55's in my 1:1 gear. I do have a set of 275/60/15's (28" tall vs. 26" tall) but they are nitto 555R DR's that I could make it through the traps at 6400-6600rpm at which I would think the 26" hoosiers I have would be making me scream around 6800-6900 which scares me a lot with my stock 89k shortblock
Sorry for the looong *** post
Old 07-04-2011, 02:35 PM
BrianC98Z28's Avatar
why would the hoosiers make your rpm go up? I dont know about hoosiers, but I know ET Drags grow bringing the RPM down. Im willing to bet with your 3.55s youll be fine even on the drag radials. With my 3.90s and 26in ET Drags and TNT 175 I was crossing ruffly 6500 shifting at 6800 on the jug. Now on the street with the 3.90s and my 275/40/17s Id run outta gear at around 123 ish and be on the rev limiter. Now with 3.42s I can run it out on the street tires to over 135.
Old 07-05-2011, 12:46 AM
It has nothing to do with the brand, lol. It has to do with how tall the two tires are. The hoosiers are 275/50/15's and the Nitto's are 275/60/15 about an inch and half taller. Taller tire will bring the gear ratio down numerically thus lowering the rpm in which I cross the traps at.
Old 07-05-2011, 12:50 AM
And I am really not trying to be a ***** I am all for going ballz deep at a moments notice, but I'm trying to save this motor for my S-10 when the 370/390 goes in this winter
Old 07-05-2011, 11:41 AM
What kind of stall do you have? stall speed and str if possible, i'm trying to figure out roughly how high you stall is compared to mine since you say you can cross the traps at 6500 with 3.90's and a 26" tall tire on n20 which will make a looser verter obviously flash higher making the rpm's go up more. I maybe can cross at 6200-6300 it sounds like right in my sweet spot. Damn that is going to kill me in the 1/8th though. I'm thinking now I should of gone down to a 2.90 or something 2.73 instead of going up to a 3.55. I was having to shift into 3rd RIGHT at the traps or go through on the limiter in 2nd at 6900-7000 which I don't like at all. I hope my shift extensions aren't too bad with this new converter...
Edit Added: But, now that I think about it, I was on my street tires 305/35/18's and they are heavy (rims in pic in sig) and 3.08's really bringing my rpm's down, and slowing me down. I am going to be using my 15" race wheels soley at the track or my 17" ZR1's. I have the choice between a 275/50/15(26") or 275/60/15(28") at my disposal for them and the ZR1's have 315/35/17(26") on them. The street tires are 26.4" where as the hoosiers and nitto's are 25.8" and 27.8" respectively and the 315/35/17" mickey et street II's are 25.6". that taller street tire was bringing my rpm's down. With the 3.55's and a shorter tire it will bring the rpm's up considerably in the same spot on the track, which will have me shifting a lot earlier into 3rd in the 1/8th helping my mph out a lot. I'm gonna try to short shift 1-2 as best I can. At the 1/4 I will use the Nitto's to lower the gear ratio down some and try it out to see if I can go through the traps at a RPM I am cool with. The guy I bought them from said with LCA's, Adj. PHB, Lid, Headers, ORY and exhaust he got a 1.6x 60' on them, so I will see what I can do with them.
Quick Reply: New 4L80E question
