3200 stall good for cam only car???
Old 07-07-2011, 08:40 PM
LS1TAUTO's Avatar
Default 3200 stall good for cam only car???
I plan on gettin a circle d 3200 stall but need to kno if it will hold up without a tune for awhile??? Im ganna cam it soon lookin for maybe a torquer v2 or maybe ms3 or ms4... Plan on doin either 4.10 or 3.42s im thinkin either nice long gears or hard short 1s either way im goin with a 3200...i need dd stall cuz this car will be driven
Old 07-07-2011, 09:27 PM
+badss+'s Avatar
id go with 3.73's hence my sig.
Old 07-08-2011, 12:18 AM
Restricted User
z99ls1's Avatar
If your going with anything above the torquer v2 I would highly recomend a bigger stall. I am only going with the 228r wich is a little smaller than the v2 and im still wishing I had bigger than my 3400 stall. With ms3 or ms4 your going to need a 3600 stall minimum. With the v2 I would go with a 3200-4000 stall. Definately nothing smaller than the 3200
Old 07-08-2011, 01:26 AM
TXZ28LS1's Avatar
I have and daily drive a vigilante 3200 with 3.73 and a 230 cam. It drives fine no problems at all. Amazed how stock my car really drives. I would definitely step up to a bit more stall honestly. I wouldnt go any smaller than a 3800 stall for a daily driver.
Old 07-08-2011, 01:36 AM
LaBLKv6Z's Avatar
233/238 112lsa, 4.10's and daily driving with the Circle D 3200. It's a great budget tc imo. Pulled a 1.90 60ft on sad street tires lol. Can't wait to see what it will do with my new setup.
Old 07-08-2011, 02:36 AM
LS1TAUTO's Avatar
Well as long aa the 3200 kicks *** i dont mind it does the rpms go up under light throttle??? (traffic throttle) or is it low like stock cuz i want kinda high so the car sounds nice
Old 07-08-2011, 12:25 PM
Quick Sh0t xMLx's Avatar
If you're going to get gears then you should definitely go with something a lot bigger. I have a 3600/3.15 gear and it drives great around town(only car I own). If you go with the 3200 you'll wish you had gone higher, especially when you get the gears in. Move up to the 4C.
Old 07-08-2011, 10:06 PM
LaBLKv6Z's Avatar
I posted some vids up of my setup in this thread.
https://ls1tech.com/forums/automatic...e-got-one.html
Old 07-09-2011, 01:05 AM
garygnu's Avatar
maybe the torquer 2,or a EPS cam.
Old 07-10-2011, 08:41 AM
Mac 2002 SS's Avatar
Ok. I'm going to sound like an ol'man on here ,but here it goes . Since you plan on a cam install in the future , you will be better off getting a 3600 stall for your car. The 3600 will help your performance more than a 3200 with any of those cams you listed.
Now if you go with a gear ,3.42 or 3.73 will work just fine. Some will say don't even bother with a gear change if you have 3.23 gear now. 4.10 gear is overkill for a A4 IMO.
When you get your stall ,you must get a tune and a tranny cooler. I know you said you want to go without one for awhile ,but it's a must do for better performance .
Best advice I can give you ........SAVE YOUR MONEY !! Cause as soon as you do one thing to your car ,then you gonna want to do another ,then another,and another ,etc,etc. Save your money and take your time ,man. It will come together sooner than you think. Good luck
Old 07-10-2011, 01:25 PM
Restricted User
z99ls1's Avatar
Remember stall first and cam second
Old 07-10-2011, 02:01 PM
Amazin1's Avatar
i dd an FTI 3200 stall with 3.42's in my TA. very streetable and a good combination for a mild car in my opinion. i also get a free reflash from Greg so when i put the heads and cam on i can step up the stall. i'm very happy with the setup for now.
Old 07-10-2011, 07:09 PM
Restricted User
Zero4488's Avatar
In my opinion for 1/4 mile performance anything smaller than a 3800 is a pure and utter waste of money....
Old 07-10-2011, 07:33 PM
Giddswat's Avatar
I would say get a Circle D 4C. I have one and it drives fine and I have had a 3200, and a 3400 stall converter.
Old 07-10-2011, 07:35 PM
02sleeperz28's Avatar
3600 and don't look back.
Old 07-10-2011, 07:49 PM
WS9 Formula's Avatar
when i did my cam swap i added a 3600 stall, tranny cooler and 3:73 gears all at once so i could save money and have it all tuned at once. i got the g5x3 on a 114 through a a4 and it drives fine to me but i only drive it once maybe twice a week. i was told that anything below a 3600 would be disappointing and a waste.
Old 07-10-2011, 08:11 PM
ULTIMATEORANGESS's Avatar
Smile
go with at least a 3600 like most are saying.
my H/C/I runs great with it.
Old 07-10-2011, 09:19 PM
Restricted User
z99ls1's Avatar
That was a kinda dumb statement. Some ppl daily drive there cars and don't want the trans to get hott or even risk it. I don't think my .7 reduction in e.t was an utter waist with my 3400 stall.
Old 08-25-2015, 11:16 PM
Senz J Lomeli's Avatar
do 3600/3800 !!!!!,, cam Only v2 very drivable
Old 08-26-2015, 05:30 AM
MonmouthCtyLS7's Avatar
Way mild stall, no lower then 3600
Quick Reply: 3200 stall good for cam only car???
