How much tranny fluid?
Old 07-20-2011, 04:10 PM
salspmp's Avatar
Default How much tranny fluid?
I just bought a used DR. Evil 4l60e. I have just installed it. While there was some fluid in it, I don't know how much (it had royal purple in it). I emptied my torque converter of as much non royal purple as I could. I then added some royal purple to it before installing.
I would guess there was only as much as what didnt leak out during the removal process. Any helpful guess as to how much I will need to put in???
Old 07-20-2011, 04:19 PM
Restricted User
z99ls1's Avatar
Install it. Start it up in park and check ur fluid when the motor gets all the way hott and add as needed.
Old 07-20-2011, 09:27 PM
ProTreeRacing's Avatar
Depends on the converter it can hold up to 2 qts or so.
Old 07-20-2011, 10:05 PM
Restricted User
z99ls1's Avatar
As long as you follow what I said you will be fine
