Longshot converter question. . .
Old 07-21-2011, 09:17 AM
Duffster's Avatar
Default Longshot converter question. . .
I'm sure there might be some distinguishing characteristics of differing converter manufactures so I'll ask.....
Anyone recognize this style/manufacturer?
It had little bits of just off baby-blue paint underneath some of the black I'm removing. I thought the 8 welds near the neck might be unique...
It uses 3 (tripod style) bolts to attach to the flex plate (I've seen some with 6 so I figure it might be relevant).
Thanks,
Duff
Old 07-21-2011, 10:59 AM
Yank's Avatar
The welds are factory on the Ford 10" converter used in some the HP applications.
they did this instead of brazing (as it cost less) it helped support the blades but not as well as the brazing process did
Looks like an old B&M unit but many company's used this core over the years.
Old 07-21-2011, 06:27 PM
Duffster's Avatar
Does the soft blue color indicate any company in particular by chance? Thanks
Old 07-23-2011, 06:24 PM
Duffster's Avatar
Another question... I've seen both 'ways' to measure the torque converter as being
1: From center of bolt hole to center of torque converter,
2: From center of bolt hole to center of other bolt hole (assuming 3-bolt convertor).
Old 07-25-2011, 02:31 PM
Duffster's Avatar
Monday...
Old 07-25-2011, 04:10 PM
Circle-D's Avatar
There are 2 measurements on a converter.
1- Diameter, this is an internal measurement on the turbine. Can not do from outside. But we can tell what converter it is and know the measurement.
2- Bolt circle, this is the diameter of the circle that the converter bolt holes are in. The one you have has 3 lugs so hard to measure. But you can measure from the center of the hole to center of the pilot and multiply by 2.
The 3 GM options are:
10.750 - 350/LT
11.080 - LS
11.5 4L80/400 3 or 6 lug
Chris
Old 07-25-2011, 06:45 PM
Duffster's Avatar
Thanks Any chance the light blue color is used by any known company for sure?
Old 07-25-2011, 09:28 PM
Circle-D's Avatar
Sorry, no help on the blue....
Chris
Old 07-26-2011, 05:15 PM
LS1Tech Sponsor
FTICONVERTERS's Avatar
That converter looks like a transmission crafters converter. kind of blue gray
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
