Those running a 4l80e with 4l60e segment and relay.
Old 07-24-2011, 01:32 PM
LTX355's Avatar
Default Those running a 4l80e with 4l60e segment and relay.
All the wiring is done... nothing has been done to the tune... I only have second gear and reverse... will the codes have to be overriden to get this thing to shift right? Or is there something else wrong?
Old 07-24-2011, 05:02 PM
MUSTANGBRKR02's Avatar
You have to delete the codes to get it running right.
Old 07-24-2011, 07:37 PM
Moderator
Vince B's Avatar
Do you have power at the main case connector?
Old 07-24-2011, 09:23 PM
White.Lightning's Avatar
Details?
Old 07-28-2011, 06:17 AM
LTX355's Avatar
Update... I had been trouble shooting this for a while slow67 helped me out quite a bit... explained what the trans needed to operate. I had it wired up right but the relay was not switching signal to ground 3rd. Replaced relay and all problems solved. Truck runs like a champ. Can't beat this way of running the 4l80e.
Old 01-11-2012, 05:56 PM
T/A KID's Avatar
Anyone care to share how to do this, I got my 4L80E running today and I hate the unlock when at zero throttle, then locks again with throttle. Id rather it operate like a 4L60E lockup.
Old 01-11-2012, 06:37 PM
PM slow67
Old 01-11-2012, 08:00 PM
Cam72aro's Avatar
I am thinking about doing mine this way too. Hate the unlock when you let off the gas.
Old 01-11-2012, 09:25 PM
joecar's Avatar
Basically:
- invert the 2-3 shift solenoid signal using a relay;
- drive TCC PWM using TCC Enable, or gate TCC PWM thru a relay controlled by TCC Enable.
Old 01-12-2012, 03:44 PM
I would definetly do this. It makes the car a dream to drive.
Old 01-12-2012, 07:47 PM
Cam72aro's Avatar
Its already a dream going from the th400, lol. I think once I get the motor tuned I am going to work on doing this.
Old 01-22-2012, 12:37 PM
T/A KID's Avatar
Joe does this mean I will still have the 4l80E PWM? Most set theres up to 90 so it locks hard, but I like to set mine up to be a little softer (not like stock, but in between really) can I still do this with the swap?
Also I suppose the codes need to be set to 3 No error Reported?
Thanks, thanking about making this swap.
Old 01-23-2012, 09:20 PM
FrankSS's Avatar
Also want to know how to do this on the cheap... Is there a full writeup somewhere?
Quick Reply: Those running a 4l80e with 4l60e segment and relay.
