4L60e help
Old 07-25-2011, 09:06 AM
RedEvilz28's Avatar
Unhappy 4L60e help
Im havein problems wit my 4L60e i just got it rebuilt and got a new val body put in cause it was stickin i put the trans back in and the val still stickin every now and then can someone tell me what the problem is.
Old 07-25-2011, 01:17 PM
LS1_K1DD's Avatar
It throwing any codes? Elaborate a little more on your problem.
Old 07-25-2011, 03:11 PM
RedEvilz28's Avatar
It's not thrown no codes it just stickin in 2nd gear it won't go to third til I take my foot off the gas and it get to 1000rpms
Old 07-25-2011, 03:18 PM
LS1_K1DD's Avatar
You sure it's stuck in 2nd? And not 3rd? Does it take forever to accelerate? Have a stall or anything done to the transmission? Does it shift hard? Give me some details here.
Old 07-25-2011, 05:39 PM
RedEvilz28's Avatar
It has a 3600 stall but it was doin this when it was stock it been rebuild 3 times it shift hard in 2nd but it sticks in 2nd
Old 07-25-2011, 10:47 PM
LS1_K1DD's Avatar
Have you had it tuned since you installed the converter? Did you install a trans cooler when you put the stall in? Mine still had problems and wasn't throwing a code at times. You absolutely sure your not in going into limp mode? How's the fluid level? What exactly did you have "rebuilt" in the trans. Trying to help you here man, the more details you can give us the easier we can help you.
Old 07-26-2011, 10:31 AM
RedEvilz28's Avatar
ok i bought the car a year ago it was shifting fine so 2 weeks after i bought it the valve started sticking and it been doin it every since my car has been tune now cause i have mods done so the third gear went out 2 times and yes i have a trans cooler im not sure if its going into limp mode we put it on the scanner and it was showing some negatives in the pressure when u give it gas
Old 07-26-2011, 10:32 AM
RedEvilz28's Avatar
the guy who rebuild it went thru the trans and put a new valve body in it and it still sticks in 2nd
Old 07-26-2011, 12:12 PM
LS1_K1DD's Avatar
Limp mode would mean it would be stuck in 3rd gear, that's the reason i ask if your sure it isn't stuck in 3rd instead of 2nd. When the PCM thinks the transmission is in danger is when it goes into Limp Mode. The PCM pulls timing and adjusts line pressure.
So you say it shows negatives in the pressure when you give it gas. Does it take a decent amount of throttle to get it moving when your at a stop sign/light and it won't shift once you get it going even if it's close to redline?
Try disconnecting your negative battery cable, leave it off for a couple minutes put it back on. Check your fluid level. When is the last time your filter was replaced? Start it up after checking all of the following and take it for a ride, just make sure not to beat on it. Have you tried manually shifting your car? I know it's not a good thing to do, but it seems like you have no other options here.
Did he replace any bands or clutches when he "rebuilt" the trans? And exactly when does it "stick" in to gear, you said every now and then, does that mean after the car has been running and is at operating temp? After you have been driving awhile? Cold starts?
Read through all of that and try it all and get back to me.
Old 07-27-2011, 10:50 PM
RedEvilz28's Avatar
i found out it sticks if i do a hard takeoff if i cruise i will have to shift to 3rd quickly after 2nd i tried all u said do that didnt work
Old 07-27-2011, 11:27 PM
LS1_K1DD's Avatar
Have you checked your shifter linkage another he car attatched to the 4L60? Do you have access to a lift?
Old 07-28-2011, 07:55 AM
RedEvilz28's Avatar
yes i can get access
Old 07-29-2011, 09:17 PM
RedEvilz28's Avatar
I found out its going into limp mode how do i stop that
