TH350 swap done.
TH350 swap done.
Got the car back from my buddies shop. He had to fix the linkage on the tranny so the cable could be adjusted correctly. And I had to relocate the driver side o2 sensor because it was hitting the linkage.
The car drives awsome. Even with the 4.11 gear and big converter it drives real nice. Hear is what I installed
Th350 RMVB, transbrake, stealth pro ratchet shifter, tci flexplate, FTI 4200 stall, bmr crossmember, trans cooler.
The only down side is that even though its a longshaft th350 my driveshaft is a little on the short side, so I am getting one cut to length
Quick vid showing the shifter I used. sorry for the lighting.
http://www.youtube.com/watch?v=-RZ4yhqrRJ8
little driving action. I havent hooked up the speedo yet.
http://www.youtube.com/watch?v=ob8WtiXpino
