4l80e has shifter module on it
Old 08-26-2011, 10:29 AM
Tire Smoking Tranny Blowing Director
Cool28's Avatar
Default 4l80e has shifter module on it
It's a flat square box with 2 connectors on it with the shifter lever coming out of it. Do I need this for my 4l60 to 4l80 swap? It has the 2 speed sensors the main plug and this module with 2 connectors.
Old 08-26-2011, 03:03 PM
charcold-bowtie's Avatar
The neutral safety switch? NSS, yes you will need it. I would probably just unbolt it, and leave it plugged in. SOmetimes the plugs are "stuck" and can cause other problems.
Old 08-26-2011, 03:49 PM
Cool28's Avatar
Ok just threw me there. If it's pose to be there then all good. Connectors were cut on it also
Old 08-26-2011, 04:10 PM
I hope you mean the junkyard or somebody cut them on a tranny you bought. But yes, I would say you will need it.
Old 08-26-2011, 05:34 PM
Cool28's Avatar
Nah junkyard trans. To bad it didn't have the trans line fitting in it
