Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Automatic Transmission
Sign in using an external account
Register Forgot Password?
Search
4L60E | 4L80E | TH350 | TH400 | TH2004R | Powerglide | Converters | Shift Kits
Sponsored by
PerformaBuilt Transmissions
torque converter lock up issues
Thread Tools Search this Thread
Old 08-29-2011, 04:36 PM   #1
Garage is empty, add now
macknmikey's Avatar
Trader Rating: 10
Send a message via MSN to macknmikey
Default torque converter lock up issues
I have a freshly rebuilt/beefed up 4l60e with pwm disabled via transgo hd2c kit and a tci 4L60E Race Torque Converter 10" LS1 w/ 3800 Stall Speed that was refreshed by tci when the transmission was rebuilt and
dan at masport speed shop tuned for the converter..
The problem: looking on a snap on scan tool the transmission is commanding the converter to lock up but it just wont... the only time i can really get it to lock up is if im going 80-85mph and then its kind of hit and miss
so my question is with all these new parts and tune what would keep my torque converter from locking up? the only parts that are not new in this combo are the transmission electrical components..
__________________
Both teams played hard.
macknmikey is offline   Reply With Quote
Old 08-29-2011, 04:46 PM   #2
2010 Chevrolet Camaro
Rhino79's Avatar
Trader Rating: 7
Either the misfire tables in the tune need adjusted, OR the clutch lining on the tci converter is trash. A friend of mine on here literally had to send his converter back to tci 3 TIMES for this issue. It could be just a tuning issue though, otherwise, i'd say drop the pan and look for a black substance in the fluid.
__________________
2010 Camaro 1SS L99
GPI Custom SS4 VVT Cam, BES Ported Heads, Vararam, LT'S, Circle D 1E, GM 3.91's TUNE
All work and tuning performed at Gwatney Performance Innovation
10.45@133.55 All Motor Stock Bottom
Rhino79 is offline   Reply With Quote
Old 08-29-2011, 04:52 PM   #3
macknmikey's Avatar
Trader Rating: 10
Quote:
i was under the impression if it detected misfires it wouldnt command the converter to lock up..? the converter has just been refreshed, and the fluid is clean.
__________________
Old 08-29-2011, 05:25 PM   #4
2001 Pontiac Trans Am
ws6fitz's Avatar
Trader Rating: 0
Send a message via AIM to ws6fitz Send a message via Yahoo to ws6fitz
Misfires would be a reason that the converter isnt locking up. Is your car throwing any SES codes?? Could also be line pressure in the trans is not adjusted accordingly. I would call your tuner and find out what your tables are set at and go from there.
__________________
2001 Pontiac Trans Am WS6
Performance Mods: 6.0L Custom Front Mount Turbo, CX Racing intercooler, Speed Inc. TU1cam, Precision 46mm WG, FLT Trans, Yank SS 4000 Stall.
2012 Ford F150 with Ecoboost - Stock
ws6fitz is offline   Reply With Quote
Old 08-29-2011, 05:27 PM   #5
macknmikey's Avatar
Trader Rating: 10
Quote:
zero codes, and she doesnt misfire..
she used to run pretty rich but i think i got that figured out with a map sensor loose in the intake
__________________
Old 08-29-2011, 11:27 PM   #6
Gilbert@Ace Racing's Avatar
Trader Rating: 0
If you are using a scanner to verify that the PCM is commanding lockup... Then indeed it is commanding lockup and the problem is not misfires.
In my opinion you need to remove the TCI converter, set it in a large steel can marked junk ane go buy a nice torque converter. I am not being a smart ***. I am giving you the best advice a 25 years professional in the industry can give you. In my career I have replaced more defective torque converters from that company than any other company.
Do your self a favor and make it go away friend!
g
Gilbert@Ace Racing is offline   Reply With Quote
Old 08-29-2011, 11:44 PM   #7
macknmikey's Avatar
Trader Rating: 10
Yeah, I planed on it for the 4l80e but I got a good deal and a refresh.. Figured I would be good for a year or two.. When it does lock up it feels good and firm
__________________
Old 08-30-2011, 06:03 AM   #8
Trader Rating: 0
Give me a shout today... I'd like to discuss this issue with you in detail. If it feels firm when it does lock up then indeed the converter may be in good shape.
g
Old 08-30-2011, 11:42 PM   #9
Trader Rating: 19
You can also replace the torque converter clutch solenoid it could be stuck.....
LosLs1's is offline   Reply With Quote
Old 08-30-2011, 11:58 PM   #10
macknmikey's Avatar
Trader Rating: 10
Quote:
I was thinking that as well but then I started thinking if that was the case why would it only lock up at 80-85mph and not just randomly at any commanded time
__________________
Old 08-31-2011, 12:17 AM   #11
macknmikey's Avatar
Trader Rating: 10
So basically what conditions would be different at 80-85mph compared to normal lock up speeds besides rpm. Im rusty on transmissions but line pressure must be one.. But in that case technically I should be able to drop it to third match rpms and get it to lock up lower then 80-85.. Granted IV never tried that but i dont think it will happen but I'll try tomorrow
__________________
Old 08-31-2011, 12:55 AM   #12
lemons12's Avatar
Trader Rating: 70
Two friends did the same thing. Common with tci converters, I dont know what causes it.
Either way, i would pull it and get a quality converter.
__________________
SLOTH RACING
RAPE EVERYTHING
Ws6 A3 370 S480
lemons12 is offline   Reply With Quote
Old 08-31-2011, 01:08 AM   #13
macknmikey's Avatar
Trader Rating: 10
Im not replacing a brand new converter till I know that it is infact the problem.
__________________
LS1Tech
Pontiac Firebird
Paid Advertisement
Similar Threads
Thread Thread Starter Forum Replies Last Post
TCI Super Street Fighter #243110 hifi dream Parts Classifieds 15 12-31-2014 05:25 PM
4L60E fluid and torque converter not locking up CamaroManLS1 Automatic Transmission 12 10-13-2013 06:52 PM
Non PWM Converter LTWONZ28 Automatic Transmission 1 11-18-2012 01:44 PM
4L60E issue. Torque converter problem or transmission problem pdbq Automatic Transmission 6 07-28-2012 04:00 PM
4L80e lock up problems, bad converter? gta324 Automatic Transmission 6 08-03-2010 06:53 AM
Tags
4l60e, camaro, converter, disable, lock, lockup, ls1tech, misfire, pwm, speed, tcc, tci, torque, transmission, tunem
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Join Ls1Tech
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Service - Privacy Statement - JOBS
Emails & Contact Details
