Newbie 4L80 owner, is this how stall should work?
Old 11-05-2011, 11:03 AM
  #81
Circle-D's Avatar
We can definitely tighten your converter up, logistics is the problem. There are also benefits to a looser converter on a turbo setup, it spools easier and faster so staging is not a problem. If you want to shoot me an email be glad to see what we can come up with.
Chris
Old 08-07-2012, 10:47 AM
  #82
Vetal's Avatar
Originally Posted by slow67
I don't quite trust that, I'd log engine RPM and output shaft RPM and compare them.
Assuming 5400 rpm engine rpm and 4400 Dshaft rpm, driveshaft, thats a tick over 20%. It will probably be more efficient if you can turn more RPM (usually converters lockup more in the 2nd 1/8 mile compared to the 1st).
Rereading the topic came across this and wanted to post latest data I got.
In 3rd at 5800rpm trans shafts turn at 4750, then trans rpm catch up engine a bit. Too much or not?
Old 08-07-2012, 04:15 PM
  #83
Gingervitis Addict
slow67's Avatar
So above 5800 it tightens up a lot?
Old 08-07-2012, 06:16 PM
  #84
FastKat's Avatar
Not sure if this was discussed in the earlier pages, but I don't think the later 4L80E has a "hard" on-off lockup solenoid - does it? I think the solenoid(s) applies pressure as needed depending on a variety of variables. This might result in some slip if engine torque spikes. I think this is done to protect the transmission, though I could be wrong.
Old 08-07-2012, 09:02 PM
  #85
joecar's Avatar
The TCC apply is ramped up to soften the feel (perceived by non-car persons to be a good thing), but once it's locked it does not slip;
if it slips then it's going bad or the engine has too much torque and needs a better TCC (multi-disc);
the TCC will quickly go bad if it slips for any significant amount of time (and will most likely take out the rest of the trans with it);
the PCM uses other means to protect the trans/powertrain (torque management).
Old 08-08-2012, 04:41 PM
  #86
Gingervitis Addict
slow67's Avatar
^^ He wasn't asking about clutch lockup, but converter efficiency.
Old 08-09-2012, 01:30 AM
  #87
Vetal's Avatar
he was probably answering the other guy
Regarding efficiency, I don't have much data yet from 1/4, only good log I got shows that at 5800 TC slips about 1000rpm and at 5900 about 820rpm, and engine rpms climb very slowly from 5800 to 5900, while TC seems to be catching up a bit
Old 08-15-2012, 08:44 AM
  #88
White.Lightning's Avatar
Good info in here!
Old 08-29-2012, 04:34 AM
  #89
Vetal's Avatar
Another idea I got to improve my terrible mileage is paddle shifting my 4L80 and manually locking converter, to act more like manual tranny and use more low revs around city.
probably would need some interceptor box then, that would intercept signals from PCM to tranny solenoids?
Old 06-14-2013, 03:29 AM
  #90
Vetal's Avatar
I checked logs from last race and by the moment gear is changed, engine rpm is 6000, and input shaft around 5200. engine rpm climb very slow and converter is catching up. Does it mean I should adjust so it changes gears later? Maybe some 6200rpm
Old 06-22-2013, 12:07 AM
  #91
MillsMotorvation's Avatar
I would say try between 6200-6500, good info here!
Old 07-03-2013, 08:57 AM
  #92
Vetal's Avatar
Something weird happened today, I lost 4th gear Hardware-wise everything is fine since when I command 4th from laptop, it changes to 4th. But by itself it doesn't shift 3rd->4th. What could it be?
Old 07-03-2013, 09:29 AM
  #93
Jake's Performance's Avatar
Possibly a code causing it to not shift.
Old 07-03-2013, 09:44 AM
  #94
Vetal's Avatar
Nope, no DTC's...
Old 07-03-2013, 01:03 PM
  #95
Vetal's Avatar
OK now it doesn't want to shift to 4th even from laptop... What could be the cause?..
Old 07-03-2013, 02:45 PM
  #96
Does it have 1st gear?
Fluid still good?
Could be a stuck 3-4 shift valve, solenoid issue, OD clutch, shifter adjustment, etc.
Old 07-03-2013, 06:21 PM
  #97
Vetal's Avatar
Fluid still good?
Yes, all other gears are fine. Fluid looks nice and clear, level is right at the max.
I'm pretty sure in the morning it still engaged 4th if commanded from laptop...
What else could I check?
Old 07-04-2013, 01:24 AM
  #98
Vetal's Avatar
I tried resetting PCM (disconnect battery for 15mins) but it didn't help
Old 07-04-2013, 05:54 PM
  #99
Vetal's Avatar
Jake, I've created separate thread to get help with this trouble, could you please check and give your ideas?
https://ls1tech.com/forums/automatic...ear-4l80e.html
Old 04-22-2014, 10:47 AM
  #100
Vetal's Avatar
I couldn't believe my luck when I found that somebody here locally offers John Deere Hygard oil ))) If I'm not sending my converter to USA to tighten, I will use this oil
Quick Reply: Newbie 4L80 owner, is this how stall should work?
